Headlight Switch, Farmall Super A
John
05-21-2003 06:02:55
Where can I find a headlight switch for this tractor. And what is the small spring like thing on the back of the switch that goes from one screw to the other. Thanks for any help.
Red Dave
05-21-2003 08:55:10
 Re: Headlight Switch, Farmall Super A in reply to John , 05-21-2003 06:02:55
If you want replacement, but don't need original, any Case/IH dealer should be able to get one for you. Or call Carter & Gruenwald at 608-455-2411.
If you want an original, try a used parts supplier such as Steelwheel ranch or Wengers. A web search will give you links to them.
The "spring like thing" is a resistor for either the generator field circuit or for dimming the lights.
