Replacing seals on hydraulic loader
scottb in iowa
05-25-2003 21:25:44
The loader (don't know brand) on my tractor (AC185) won't hold position. I suspect it is leakage in the cylinders. Can anyone recommend a procedure for checking and/or replacing the seals in the hydrauling cylinders?
GEORGE MORALES
11-15-2005 07:53:48
 Re: replacing seals on hydraulic loader in reply to scottb in iowa, 05-25-2003 21:25:44
WE PROBABLY CAN MATCH UP THE SEAL THAT YU REQUIRE FOR YOUR TRACOTOR IF WE CAN EITHER GET A DRAING OF THE OLD SEALS OR THE USED SEALS COULD BE SENT IN TO US TO BE MATCHED UP GET BACK TO US AT 801-973-7325 WE ARE LOCATED IN SLC UTAH
Unimog
05-26-2003 10:30:39
I would check the control valve first. It might
need the seals and o-rings replaced. The cylinders
usually don't both start leaking down at the same
time.
