IH 504 hydralic problem
Sean Dickson
05-30-2003 15:27:16
Rear hydralics wont lift. Changed the filter it worked for a day or so now it wont work again. Pump is working because when I hit the front hydralics I can hear it trying to work. I dont have a front bucket yet. Anyone have any ideas???
Alton
05-30-2003 17:42:30
 Re: IH 504 hydralic problem in reply to Sean Dickson, 05-30-2003 15:27:16
Check pressure of the pump and it will give you an indication if it is working. If little or low pressure look for restriction in suction, or relif setting. If no presure indicating bad pump, check the flow and pressure together. You really need a flow chart for your tractor to idintify the components and operation of system.
jayman
06-04-2003 22:32:28
 Re: Re: IH 504 hydralic problem in reply to Alton, 05-30-2003 17:42:30
You may find an article here that will give you some clues:
