Engine pulley
Ed
06-10-2003 20:45:31
I need to replace the engine pulley on a Craftsman 12.5 HP tractor, about 10 years old (Model # 917.255441). I removed the bolt at the bottom of the pulley, but the pulley remains firmly attached. What do I need to do to remove the pulley in order to replace it?
rhouston
06-11-2003 12:02:51
 Re: engine pulley in reply to Ed, 06-10-2003 20:45:31
I found a vertical shaft 15 horse engine that did the same thing. Turns out the key way in the pulley was starting to go. I gave it a slight turn in the opposite direction of engine rotation and it came right off. may or may not be your problem.
