1943 Farmall H cutting out
Kent in N.B.
06-19-2003 17:49:21
Hi, my 43H will start great and run for a few minutes, and then shuts down. I cleaned the sediment bowl(half an inch of particles)and ran some fuel out of the tank. Tractor ran for about 10 minutes at varying throttle settings and then cut out. Do i have to drain the tank and flush it , or remove the tank to clean? Also how do I prevent this in future?
sm
06-20-2003 06:11:34
 Re: 1943 Farmall H cutting out in reply to Kent in N.B., 06-19-2003 17:49:21
you should really post this on the Farmall forum -you'll get more responses
John
06-19-2003 18:39:44
If you think that you are getting dirty fuel from the tank, put an inline filter in. You can leave the metal fuel line there, just tape it up and use rubber hoses. This is only a quick fix until you flush out the tank. Also you may go through a lot of inline filters but this beats taking the carb apart all of the time. On the other hand, maybe your tank will self clean over time. I flushed my tank out, still get some particles in the sediment bowl and have a temporary inline just in case.
Dean Myran
06-27-2003 21:32:28
 Re: Re: 1943 Farmall H cutting out in reply to John, 06-19-2003 18:39:44
If after experimenting with the fuel advice, and it still doesn't solve the problem, I would check the coil. Once they are shot, as soon as they warm up, they will kill the tractor just as quick as if you turned off the switch.
