Ford 640 Carburetor
Chris
06-20-2003 08:45:52
This tractor was recently pulled from the weeds and started after 8-10 years of sitting up. We re-set the timing, replaced the plugs, wires, etc. However, the carburetors is giving me trouble. The gas leaks out of the carbureator so I had to install a shut off valve to keep it from doing so. Also, I installed a reuild kit but it didn't stop the leaking. Any suggestion on how I can alleviate this problem?
Thanks,
Jone
06-28-2003 05:55:23
 Re: Ford 640 Carburetor in reply to Chris , 06-20-2003 08:45:52
on my ferguson TEA, the float didnt close the needle valve in the top of the carb, so i had to shim it down a bit, now its running as good as new....
