Fiat 211Rb
Ian Storrie
06-24-2003 22:03:10
Can anybody help with information regarding replacement gears for the Fiat 211Rb. My friend has one of these and the top gear is missing a few teeth.
Question is, can a gear from a Fiat car gearbox be used as a replacement, and if so any ideas on what models are suitable?
Any help would be appreciated.
Ian Storrie Australia.
ray
06-25-2003 12:57:46
 Re: Fiat 211Rb in reply to Ian Storrie, 06-24-2003 22:03:10
Did you try finding a generic replacement? Count the teeth, measure the height of the teeth,measure the width,measure bore and measure the outside diameter. You might have to bore the diameter and broach a keyway but you should be able to find a match. (Look on line - if you have that info post back and I'll check and see if I can find a match)
