1945 H FARMALL • NEED HELP
CARL PATTON
07-01-2003 19:28:21
RESTORING. ANY HINTS ON REMOVING THE RADIATOR.
STERRING ROD GOES THRU TOP TANK OF RADIATOR.
Phil Libbert
12-17-2006 14:10:25
 Re: 1945 H FARMALL • NEED HELP in reply to CARL PATTON, 07-01-2003 19:28:21
1. remove the hood and grill
2. there should be a big nut on the front of the steering mechanism. - remove it
3. split the steering shaft at the u-joint under the hood.
4. spin the steering shaft and it should thread out of the gear - remove shaft out of the front.
26Red
07-02-2003 10:33:48
You have to remove the steering shaft. Unscrew the large pipe plug on the front bolster, then unscrew your steering shaft- it should come out the front. Don't forget to unhook the universal joint by the oil and temp gage.
