Farmall 200 steering wheel removal
Frank Z
07-03-2003 15:34:19
What is the trick to getting the nut off of the steering shaft to remove the steering wheel? Wrenches and biceps don't seem to budge it....
Georgia Ann Davis
07-03-2003 22:07:58
 Re: Farmall 200 steering wheel removal in reply to Frank Z, 07-03-2003 15:34:19
An impact wrench and a six point socket will do it a lot of the time. The decret of the impact wrench is the vibration and the rapid hammering of it and also the six point socket won't slip on the corners of the nut. It always helps to soak it a few times with penetrating oil before you start also some times alternating between loosening and tightening will work the oil in to the threads. To get the wheel off after the nut is off, I have had good luck getting on the backside of wheel with an air chisek that has a dull edge and letting it jar it loose. Gene
