Deutz Allis 1920 PTO's not working
Robb Parthemore
07-13-2003 17:46:40
Help! I have a Deutz Allis 1920 Garden Tractor and the PTO's quit working on me. I went out to mow my property when the PTO's just would not start up at all, no lights, not attempted take off, nothing. I figured my cheap battery was the issue, so I bought a new one, but this did not help. Does anyone know of some checks I can perform to locate my problem, Are there parts to fix this thing if I do figure out what the problem is? It has 1400 hours on it, and I acquried it about 2 years ago, in sad shape. I replaced both head gaskets, fuel pump, crank seal. and some tire valves and she's been running great ever since. Any help is GREATLY appreciated. Robb Parthemore
lrparthemore@yahoo.com
Joe
07-18-2003 19:34:49
 Re: Deutz Allis 1920 PTO's not working in reply to Robb Parthemore, 07-13-2003 17:46:40
Robb, the clutch on these is electric. Before tearing into the clutch (expensive to replace), you need to be sure you are getting 12 Volts to it. There is a 2 wire connector at the clutch. Unplug this and verify you have 12V there when the clutch should be engaged. If not, you may just have a bad switch. You should have a model/serial tag on a sticker on the frame. Get the 169XXXX number on it. Go to the Simpletractors.com web site, click Parts & Manuals and you will find a link to download the manuals. I belive there is a wiring diagram in either the parts or operation manual.
Robb Parthemore
08-02-2003 09:11:58
 Re: Re: Deutz Allis 1920 PTO's not working in reply to Joe, 07-18-2003 19:34:49
OK, with the switch in the on position, I get a solid 12volts plus reading at the wire near the clutch..I am thinking I do not want to hear the next step. Where do I look for a new clutch assembly??? Thanks for your help
Robb Parthemore
07-21-2003 18:10:39
THanks Joe, I Tore into the clutch before I read your reply. I recognized a wire that may have been shorting out, I replaced it and at first it didn't work, but after a couple of tries it now works???? I have had a bad battery too, and am getting a brand new one this week for it. I hope this thing lasts a while longer, any idea of where I can find parts? I was told the Simplicity Sunstar is an exact duplicate of this Deutz? Do you know??
