Restoration & Repair Tips Board
A farmall steering
Michael Reek
07-18-2003 10:38:27
is the a kit or a fix to take the play out of the steering of an A farmall, the steering wheel turns approx. 1 turn before the wheels will turn thanks Mike
Vern
07-18-2003 21:38:49
 Re: A farmall steering in reply to Michael Reek, 07-18-2003 10:38:27
Check the arm that is at the bottom of the steering box. If there is a bolt through the butt end of the arm try tightening it. These units are notorious for coming loose. If it is worn enough you may have to shim the gaps and then tightening it.
