Restoration & Repair Tips Board
generator-alternator conversion
Al
07-21-2003 11:25:40
Does anyone have a wiring diagram or tips on converting a Ferguson TEA20 from generator(6V) to alternator(12V)
D13
07-25-2003 19:07:22
 Re: generator-alternator conversion in reply to Al, 07-21-2003 11:25:40
There are a couple of articles about Ford conversions and International conversions in the "Articles" columns.
Why convert? It cost $75 to get my generator rebuilt. And that's if the voltage regularot is OK. A 12 alternator cost me $27, another $10 in misc parts, and now I can swap batteries between rigs or jump start one to another without worrying about voltage and polarity. Not ot mention the Delco conversion on my MF202 required fabricating 1 bracket (20 minutes including paint) and eliminated the fire-starting wiring that was on the tractor. 4 wires later life is no hassle, and I can enjoy my beast rather than spending half the time recharging the battery.
alex chong
09-16-2003 11:03:28
 Re: Re: generator-alternator conversion in reply to D13, 07-25-2003 19:07:22
anyone can tell me where to get the alternator repairing book in germany,i would like learn to repair my DENSO(japan make) alternator,thk u
Jim WI
07-22-2003 10:46:33
Jake's given a pointer to the wiring diagram for the Ford N's which may be all you need.
My question is why you want to convert? A 6V system in good condition will start just about as well as a 12V system. Many times, maintenance on the electrical system gets neglected: Nice, thick battery cables designed for 6V systems get replaced with the thinner version designed for 12V systems. Connections get corroded or loosen over time. Correcting those sorts of problems is cheaper than converting and may be all that is needed.
On the other hand, there are other reasons for converting. In my case, the generator and battery were both bad so converting didn't cost more than fixing. I also had a 12V sprayer.
It's worth thinking about why before jumping into it.
jake
07-21-2003 20:11:58
Al use the link in the 9n wiring request in the post just above yours. there is a diagram of a 12v conversion of the 2-9-8Ns. The regulator is in the alternator and conversion consists of reversing several connections and a dropping resistor or changing coils.
