Restoration & Repair Tips Board
Adjusting valves on M Farmal
Devin Brewer
07-27-2003 17:23:31
I recently had some problems with my M Farmal.To make a long story short I have repaired the problem and now I need to adjust my intake and exhaust valves. The problem is that I have no idea what the tolerance/adjustment measurment is for either exhaust or intake. If anyone could tell me I would greatly appreciate it. This is a gas engine. Thanks in advance.
Devin
Farmer John
07-29-2003 10:28:18
 Re: Adjusting valves on M Farmal in reply to Devin Brewer, 07-27-2003 17:23:31
.017 hot. adjust them to .018 if cold then re-check after it warms up
CNKS
07-28-2003 18:09:05
I could look it up for you, but you can just as easily go to tune up specs at www.weberstractorworks.com. Final adjustment is made with the engine hot, you can make the inital setting 1 or 2 thousands looser.
Devin Brewer
07-30-2003 05:10:39
 Re: Re: Adjusting valves on M Farmal in reply to CNKS, 07-28-2003 18:09:05
Thanks Farmer John and CNKS for helping out with my problem. I appreciate it.
Devin
