Restoration & Repair Tips Board
12 volt conversion
bill
07-31-2003 14:26:04
i have a 1951 to 20 ferg. i put a gm alt. on it the type with 1 post and a 2 prong plugin, i tied the larger red wire on the plugin to the post on the alt, then ran the wire to the battery, the small brown wire on the plugin to the charge light, and i put a ballast reister in the wire from the swich to the points, but the problem is it keeps burnning out the voltage regulators, what have i done wrong?
jake
08-01-2003 08:15:41
 Re: 12 volt conversion in reply to bill, 07-31-2003 14:26:04
Bill your connections are wrong, the plugin [pigtail] #2 is connected to the hot wire on the alt and #1 goes to either the ignition switch or the charge lite, this wire is used only to activate the alternator. the pigtail wires that my local parts store sells have for #2 red,#1 white. Check out the article section to the left there are several upgrades described but the hookups are the same. Question did you put the battery in with the ground negative as required by the alt, if you use a pos ground the alt will be fried.
bill
08-01-2003 18:15:47
 Re: Re: 12 volt conversion in reply to jake, 08-01-2003 08:15:41
jake i have #2 tied to the alt hot and then to the pos. side of bat and #1 to the light and neg ground. but it burns out volt regulators, thanks bill
