Restoration & Repair Tips Board
Stress crack in 1.0mm steel tubing
Dan O'Neill
08-13-2003 06:09:20
Ive a crack about 1/2" wide in my bike frame, its under pressure from the rotory disk brake which has forced the metal apart near a weld which holds a bridge on. i need to know how i can repair this and the best way of doing it, either just welding it or using a plate to cover it and reinforce it. ill also need to know how to go about this. also if anyone is knowledgable about the process of framework painting usng 'home' tools (air pressure gun)
