Restoration & Repair Tips Board
No oil pressure
dw
08-28-2003 18:08:26
I have no oil pressure on a farmall c which I replaced rings, bearings and main bearings. The oil pump looks o.k. not warped. put in new gasket.
Any ideas?
Thanks.
Oldfarmboy jim
08-30-2003 22:57:02
 Re: No oil pressure in reply to dw, 08-28-2003 18:08:26
Some shop service manuals will tell you to pack the oil pump with vaseline or light grease and prime the oil pumpreturn passages with oil all the way to the pump(apparently by pouring oil into the return passages in the rocker arm area) This way you get a siphon effect of oil from the pan to the pump and it keeps you from running the engine without lubrication. What does your manual say?
RayP(MI)
08-29-2003 17:53:26
If it's the same pumpas on my 200, the bottom plate was worn by pump gears. I smoothed down the base plate, and put in a thinner gasket (homemade). Oil pressure increased noticably.
