Restoration & Repair Tips Board
John Deere B Serial Plate
Dave S. (OH)
09-05-2003 22:21:45
I'm getting down to the sanding and about ready to paint my 1940 "B". The serial number plate is still on it but isn't in that great of shape. I can still read all of it so I'd like to preserve it as best I can. What I want to know is if there is a way to take it off, Paint the tractor and then put it back on. The rivets that hold it on look like some on another piece of equipment that I had and those had like a spiral on the stem of the rivet and could be removed by turning them like a screw. If these aren't like that or at least removeable and reuseable then I'll just tape it off and paint it like that... Thanks in advance.
Bguy
09-07-2003 07:27:12
 Re: John Deere B Serial Plate in reply to Dave S. (OH), 09-05-2003 22:21:45
I have had very god luck removing these by cutting a slot in the head with a Dremel tool and then useing a screw driver to turn them out. They do have the spiral groves on the back and turn out a lot easier than I ever thought they would. The studs are still available from your JD dealer when you are ready to put it back on. You can just tap them in with a hammer.
Dave S. (OH)
09-07-2003 19:06:11
 Re: Re: John Deere B Serial Plate in reply to Bguy, 09-07-2003 07:27:12
Thanks =)
