Restoration & Repair Tips Board
sandblasting
Dave ho
09-18-2003 19:41:09
What are the chances of warping the sheetmetal on an Oliver 70 by sandblasting it and if it will warp it how do you go about getting sheetmetal that is pitted badly ready for paint.Thanks
david
09-23-2003 21:09:13
 Re: sandblasting in reply to Dave ho , 09-18-2003 19:41:09
there are really good primer/fillers or a good leveling primer check auto paint supply stores
TO-35Man
09-19-2003 02:49:55
Dave...its not to hard to warp your sheet metal if your not careful...its best if you keep the blasting nozzel moving and atleast a foot or two away depending on the size of your blaster and compressor.....if you have a small one 100lb sand pot or smaller you should not have any problems just keep it moving as needed.....to fill metal blemishs (pits) when your finished blasting and primeing use a body putty it comes in a tube, use a spreader to apply a thin coat let it dry then re sand.....
if you have any more questions I can help you with post back...
Have a nice day....
David
10-14-2003 19:06:34
 Re: Re: sandblasting in reply to TO-35Man, 09-19-2003 02:49:55
I blasted my tractor tinwork with Northern tools blaster with 1/8 nozzle and about 75 psi pressure and it did ok. I never felt there was any risk of warping anything.
