Restoration & Repair Tips Board
Car Starts, but stalls when going into drive! HELP
Shanon
09-20-2003 15:55:17
I have a 1988 Pontiac Fiero 4 cyl. 2.5L that will start just fine, but sputters out and stalls when put out of Park into gear. Can anyone out there give me some ideas. I have tried a new fuel filter, new spark plugs, new plug wires, and new O2 sensor. I can't seem to troubleshoot this. Any help would be appreciated.
David
09-23-2003 13:35:46
 Re: Car Starts, but stalls when going into drive! in reply to Shanon, 09-20-2003 15:55:17
Vacum leak is a possibility. I had a Fiero that did that years ago and it was the pick-up coil in the distributor
Jason
09-23-2003 11:52:36
Sounds like your torque converter clutch solenoid. When it goes it leaves the torque converter locked up. It just the same as cramming a manual trans into gear with out engaging the clutch. You have to go into the tranny to replace it.
Jake
09-23-2003 09:02:46
That also is an indication that the EGR is stuck open causing a massive vacum leak. It can be checked by making a block from a beer can between the valve and manifold. My wife had an intermittent problem which Ford couldn't find[$60] Took it back and insisted the valve be replaced, been 3 yrs with no prob. Most "mechanics" have no idea what and how the valve works.
TO-35Man
09-20-2003 17:16:16
Don't know if you have one but try the PRNDL and or overdrive switch on tranny....you should be able to disconnect it and crank it up ,then put it in gear and pull off....but the trans wont shift into over drive...
post back if it works...
have a good day
dave ho
09-21-2003 19:46:52
 Re: Re: Car Starts, but stalls when going into dri in reply to TO-35Man, 09-20-2003 17:16:16
Sounds like it could be your TCC solenoid inside your trasmission.Check with your garage.
