9-N split
Dan O'Rourke
12-06-2001 20:34:11
Safety tip..... .. Before you cut loose the radius rods from the trans housing, support unit
under the front axle. If this isn't done and there is slop in pivot bushing, the radius rods will be torqued to shoot upward when you remove the retainers holding rods to the trans housing.
this could result in serious injury.
