Restoration & Repair Tips Board
Repair of broken rear axle??
AWB
09-26-2003 06:39:54
I have a small tractor that has a broken rear axle. Can a broken axle be satisfactorily repaired by welding? Thanks, AWB
Dick L
09-26-2003 16:52:27
 Re: Repair of broken rear axle?? in reply to AWB, 09-26-2003 06:39:54
Short answer is yes but you would eather have a machine shop with a lathe and know to indicate both broken ends of the shaft in on center. Drill and tap the shaft to a size 2/3 of the total diameter 1 1/2 times the shaft diameter deep. Connect the two halves with a grade 8 threaded stud. Weld the outter third with 7018 welding rod with a build up and back into the lathe to turn to the correct diameter. If you do not have your own machine shop it would probably save you money to get another shaft from a scrap yard.
loren
10-25-2003 19:52:47
 Re: Re: Repair of broken rear axle?? in reply to Dick L, 09-26-2003 16:52:27
Dick, curious on the 7018 spec. Why pick this rod over any other. I at first thought using the sub-arc I run at work for this. No?
