Restoration & Repair Tips Board
Ford 600 v belt pulley replacement
Clint Wilson
09-28-2003 16:58:58
How do you get the new pulley/hub on? Removing the old one was no problem because it was broken. Do you have to remove the cowling, remove the radiator hoses, take the steering shafts loose on one end of the axle, remove the four nuts holding the cast iron pan on that is beneath the pulley and roll the loose end of the wheel and axle around enough to get the pulley in? Of course the tractor would be jacked up and on blocks. Any information would be appreciated. I don't have a manual for the tractor. Thanks
r marg
10-10-2003 11:04:14
 Re: Ford 600 v belt pulley replacement in reply to Clint Wilson, 09-28-2003 16:58:58
yes you have to take it apart to put it back on and its not fun but that is the way it was made
