Restoration & Repair Tips Board
3020 j.d.
robert santi
10-01-2003 07:31:08
i have a 3020 johndeere and my fuel gauge doesn't work. my question is should i have power to the sending unit in the tank with the key on..i don't. thanks
Scott
10-03-2003 10:53:57
 Re: 3020 j.d. in reply to robert santi, 10-01-2003 07:31:08
The wire going to the sending unit is looking for a ground. To check the gauge, ground the wire to the frame, the gauge should read full. If it does the gauge is good, sending unit is bad.If not, check to be sure there is voltage going to the gauge. If the voltage is there, the gauge is bad. The variable resister in the sending unit causes the gauge to change with fuel level. Very often they will get bad spots where the gauge will read sometimes and sometimes not. You can replace the entire sending unit for about $50. Hope this helps.
JMS
10-02-2003 00:47:57
If you disconnect the wire to the sending unit, and short it against the frame, you should peg the needle on the gauge. Then the sender is bad. I think that means you should have current in the wire.
