Restoration & Repair Tips Board
International 240 others steering repair tip
Jerry
10-01-2003 08:49:59
Just a quick note for those of you who have run into a problem finding nylon sleeve bearings (bushings) that have worn out in the upper support for the steering shaft. I replaced mine with Brass Bushings that are readily available, rather than pay for the replacement shaft.
On the model 200-230-240-404 & 2404 tractors, you can use Randall Bushing Part# 1416 08. It will fit into the support and provides a nice snug fit around the steering shaft. It measures 1" long 1" OD x .8750 ID.
