Restoration & Repair Tips Board
Re: JD A Power steering
Larry806
10-03-2003 19:04:49
Most I've seen Just put a unit in the steering shaft & put a pump in the fan support bracket Take the pully off mount the pump from the back side install the pully on the frount shim with washers to get the pully lined up for fan belt
Brad
10-04-2003 07:29:09
 Re: Re: JD A Power steering in reply to Larry806, 10-03-2003 19:04:49
Thanx Larry 806. What kind or style of power steering unit can i use? Does it have to be JD or can i use some style of automotive unit? Obviously it would have to be inline(same direction as steering shaft). Any ideas?
Larry806
10-04-2003 17:10:22
 Re: Re: Re: JD A Power steering in reply to Brad, 10-04-2003 07:29:09
You'll need a Char Lynn or Bellan(sp) unit to go in the steering shaft & a auto type punp
