Restoration & Repair Tips Board
starter missing
Cletrac /conti
10-22-2003 09:27:46
I need a starter for this little thing the starter uses the same bolt pattern as an oliver 77 or farmall 450 but the nose cone on them is to large and the hole it fits in to is smaller then them 3 1/4 inches in diameter where as the farmall /oliver starters use 3 1/2 inch diameter any body know where I can find a starter for this thing any and all ideas are welcome thanks for any and all ideas
Glen in TX
10-27-2003 20:11:13
 Re: starter missing in reply to Cletrac /continemtal F-4, 10-22-2003 09:27:46
Someone with a 1940's Cletrac HG close to this guy help him find what he needs or loan him a starter to see if it would fit. Couldn't find a listing for it in books.
Glen in TX
10-23-2003 21:53:41
Are you sure it is a Continental? Most Cletracs had a Hercules or Buda. Most Continentals would have a tag on side of the engine block giving the model number. You will need this to match up something out here. I could find something in my books if you had the number of the engine. Some Continentals used some odd mounting starters that will fit nothing else.
R. Marg
10-24-2003 07:52:56
 Re: Re: starter missing in reply to Glen in TX, 10-23-2003 21:53:41
its a continel but from what a guy told me hes a fork lift guy its bolted up to the hercules bell houseing the tag is gone if it where still there I probably won't have this problem the starter that was on it was a rigged boat motor starter and of course it was not big enough to hold up so I'm trying to get the right thing or at least as right as it can be this thing would run and do work if I had a way to start it
Glen in TX
10-24-2003 09:44:00
 Re: Re: Re: starter missing in reply to R. Marg, 10-24-2003 07:52:56
Ok, knowing it is Continental or a cross of sorts with Hercules. What model Cletrac is it? A F model? I have some reference guides listing Cletracs and engines used but it doesn't give the model of the engines, only brands and 4 or 6 cylinders. Shows some Cletracs using their own engine. One wonders what these really were. Would help me know where to start looking in books. Probably a Autolite/Prestolite or Delco but have several books 8" + thick to look through. Some continental engine info is available from continentalengines.com but doubt they have starter info for this. The Cletrac model would give me a place to start.
R. Marg
10-24-2003 10:34:43
 Re: Re: Re: Re: starter missing in reply to Glen in TX, 10-24-2003 09:44:00
its believed to be an HG it has a wade loader model HGT it has a 3 speed tranmission and the contintal engine is believed to be a F model but not sure if its a 124 or 164 or maybe a little larger the disturbor is between # 2 and 3 cylinder it has a water pump on it and the govenor is on the front right hand side and thats if you are sitting on it and the starter goes on the left side hope this helps you help me Thanks for all the help Rich
Glen in TX
10-24-2003 12:18:32
 Re: Re: Re: Re: Re: starter missing in reply to R. Marg, 10-24-2003 10:34:43
That helps narrow it down Rich. Will check the books and email you later this evening with some info. You can do a web search on "old cletrac crawlers" and find a lot to look at. Found the chart I had seen before on Cletrac and there is some more links there for you to look at. I didn't look at all of them yet. Maybe someone else can be found with a Cletrac like yours and we can find out what starter is on theirs. The charts are still just showing the HG, HGF, & HGR with a Hercules? The Continental F124 was used in a lot of forklifts as was the F164 which was also on some welders too.
Wayne
10-22-2003 20:59:15
A really good starter repair shop, with a knowledgable employee willing to take a little time to help you, ought to be able to match something up by dimensions. You may even get lucky and they'll have an old book lying around that they can do it by application. We've matched up some oddball stuff over the years off old heavy equipment this way, but the place we use all the time is excellent both in customer service and in the quality of their repairs. When you get into equipment that's that old, there weren't nearly as many choices, by mfg or by size/style, as there are nowdays so it shouldn't be that hard to find a match. Good luck in your search.
