Restoration & Repair Tips Board
f-20 #'s
Bob Schuon
10-24-2003 20:11:48
I now own a stuck Farmall F-20. The tag on the tool box is gone. The number on the engine is FA87794. The number on the left frame rail is FA87794N. It looks to be a narrow tread on rubber. It also is a dual fuel model, but I'm not sure what fuels. Can any one help?
R. Marg
10-24-2003 21:03:50
 Re: f-20 #'s in reply to Bob Schuon, 10-24-2003 20:11:48
as far as it being stuck fill the cylinders with turpentine and probably the oil pan also let it sit a few days and check to see if it will turn over but don't turn it much till you drain it and put freash oil in as far as the 2 tanks 1 was for gas to starte it on and run till it got warm and the other was for distaliteor kerosine or even diesal
jim
11-07-2003 17:08:08
 Re: Re: f-20 #'s in reply to R. Marg, 10-24-2003 21:03:50
When you get your F-20 running, don't try to burn diesel in it. Kerosene or distillate will work if you can find it and your mag is hot enough, but NOT diesel.
