RESTORING STEERING WHEEL
MERRILL
12-09-2001 14:10:52
I AM IN THE PROCESS OF RESTORING A STEERING WHEEL "CRACKS". ONE OLD BOY TOLD ME TO FILL THE CRACKS WITH JB WELD, SAND IT DOWN, AND REPAINT IT WITH LATEX ENAMEL. ANY OTHER TIPS OUT THERE? WOULD LIKE TO TRY RESTORING IT MY SELF BECOUSE OF HIGH COST OF BUYING A RESTORED ONE OR A NEW ONE.
big fred
12-10-2001 08:18:58
 Re: RESTORING STEERING WHEEL in reply to MERRILL, 12-09-2001 14:10:52
I don't know how it would work on a rubber steering wheel, but Plasti-Kote makes some stuff called "Appliance Enamel" paint that works good on plastic (automotive) steering wheels. It comes in several colors including black, and is a very durable paint intended for touch-up of ovens, refrigerators, etc.
Bill
12-10-2001 07:05:17
I followed a couple of guys' advice from the archives: Fill the cracks and rebuild with PC-7 (two part epoxy stuff); let dry (of course) then sand to shape; spray a number of coats with black laquer and finish with a number of coats of clear laquer (I did about 5 coats of each). Wasn't a lot of work, and looks new. Wearing well so far too. Keeps it's rich black sheen, which I like.
Red Dave
12-10-2001 05:20:17
J-B Weld should work. I've used plain old Bondo body putty and had good results. They are both epoxies so it seems like they would work about the same.
I agree with Marty Z, I wouldn't use latex. I used a spray acrylic enamel that was made for painting dash boards. It made a satin, slightly crinkled finish that looks like a new rubber job. If you use the tractor a lot you may have to give it a new coat every 4 or 5 years. Mine is 5 + years old and still looks good.
Marty Z
12-10-2001 00:21:56
JB Weld works OK. May take 2 coats and some sanding. Don't use latex. Sandable Krylon primer and Krylon spray Gloss black does not look too bad.Flat is Ok if you prefer.
MJZ
Bubbyboy
12-10-2001 14:48:16
 Re: Re: RESTORING STEERING WHEEL in reply to Marty Z, 12-10-2001 00:21:56
I have used Bondo and then used a rubber based tool dip and have also used spray enamel immrdiately over Bondo
Jack
12-13-2001 18:36:11
 Re: Re: Re: RESTORING STEERING WHEEL in reply to Bubbyboy, 12-10-2001 14:48:16
Wal Mart also handles a high temperature engine enamel that holds up exceptionally well. Can get it in either gloss black or satin black. I prefer less gloss-looks more original on an old tractor. I have done about 12 steering wheels the first about 6 years ago and they have held up well. I agree, any of the epoxy's will work to build up with. Jack
donwisc
12-15-2001 18:51:41
 Re: Re: Re: Re: RESTORING STEERING WHEEL in reply to Jack, 12-13-2001 18:36:11
Ditto 0n the previous post using PC7. Its easy to use and sets up like iron. Good multple use epoxy.
