Restoration & Repair Tips Board
Starter not engaging, HELP
Gary
11-05-2003 12:16:21
Replaced the bendix but still just spins of sounds like its spinning...Any clues????
Bigdog
11-05-2003 16:35:16
 Re: Starter not engaging, HELP in reply to Gary, 11-05-2003 12:16:21
Make sure the bendix you got is the correct one. Some starters are identical in structure but turn in the opposite direction. The bendix could also be binding on the shaft. You could try removing the starter and kicking it over with a battery to see if the bendix is working.
old
11-05-2003 12:57:43
Whats the ring gear look like, if it has burrs on it that can stop the starter drive from going out all the way. hope this helps
