Restoration & Repair Tips Board
Stuck valve on 440 Oliver
Danny Ray
11-07-2003 07:05:20
Whats the best way to un stick the valve? Its a flat head engine with plugs on top of the head. Thanks In Advance
John Garner
11-07-2003 20:35:08
 Re: Stuck valve on 440 Oliver in reply to Danny Ray, 11-07-2003 07:05:20
Danny --
Tough question to answer.
Why is the valve sticking?
If it's simply a "gummed up" stem -- oxidized oil between the stem and valve guide -- you may well be able to free it with some chemistry. Berryman B-12 Chemtool is one of the best crud-cutters on the market, and applying B-12 to the stem-to-guide junctions, preferrably at both the top and bottom of the guide, with some mechanical push-pulling may do the trick. Some people dump a pint of B-12 in the crankcase and idle the engine for ten minutes. If you do this, drain the oil while hot and replace the filter (if so equipped).
Other solvents, including commercial "crankcase flush" of various brands, Liquid Wrench, Rislone, and Marvel Mystery Oil, can be used in the same way but will usually take longer to work.
The Rislone and Marvel Mystery Oil can be used as oil additives, and I'd personally be inclined to use a stronger solvent in the old oil, drain, and then add the Rislone or MMO to the fresh oil.
It's also possible that the valve is sticking because it's mechanically blocked -- perhaps a piece of junk got into the engine somehow -- or because the valve stem is bent. If the cause is mechanical, it's wrench time because chemistry won't take the junk out or straighten the valve stem.
Good luck with it.
John
old
11-07-2003 08:20:41
You may be able to pull the tappet cover and then carefully tap the valve closed again and cycle the engine and this till it closes the way it should. I did this the other day on a crawler engine and now all of them work right. Hope this helps
