Old case 580ck backhoe lines
joe francano
12-11-2001 08:31:22
I have a 72' 580ck 'b' model. The steel lines for the backhoe(at the bulkhead plate) were leaking badly. I tried to remove them and just put a longer hydraulic hose to the pistons so that I could eliminate these leaking parts. No luck. The rubber hoses are thicker than the steel and are pinching at the pivot point. Now I dont know where to get replacements made. I think I could probably bend ones that would suffice, but cant seem to find the steel to make these hoses anywhere. Any suggestions are greatly appreciated.
Sam Savage
12-24-2001 05:06:40
 Re: old case 580ck backhoe lines in reply to joe francano, 12-11-2001 08:31:22
Try Link The annealed, low carbon steel tubing is easy to work with. It cuts, bends, flares, brazes, and welds nicely. I made up some new lines and repaired some damaged lines on my IH T-340 and it turned out very well. I made repair couplings for 1/2" lines from the next larger diameter tube (5/8"). Ream with a 1/2" drill and it's sized perfectly for brazing. High pressure "flareless" fittings are available, but kind of pricey.
