Restoration & Repair Tips Board
John Deere 110
Matt Oney
11-09-2003 09:51:35
I started working on a John Deere 110 the other day, Kohler 8 horse, K181s. It was burning oil and it needed new rings. So I pulled the piston and all, honed the cylinder walls, installed the new rings, lapped the valves while I had it apart, and carefully put it all back together per the instructions of the online repair manuals at www.kohler.com. Well now the engine is so darn tight that the starter won't even crank it over...the tires slide when I try to pull start it (no matter how much weight is added)...we even hooked it up to a tiller and attached a belt and that's the only way we can get the motor to spin. What's wrong here? I know I didn't end up with any spare parts...and I put together everything paying attention to the little details. I'd appreciate any advice you might have on this matter. Please email me, as I will forget to check this. Thank you for your time.
-Matt
george md
11-09-2003 15:38:02
 Re: John Deere 110 in reply to Matt Oney, 11-09-2003 09:51:35
Matt,
rod cap on backwards, or no ring gap .
george
Matt
11-09-2003 16:22:59
 Re: Re: John Deere 110 in reply to george md, 11-09-2003 15:38:02
Hello. I remember the instructions on the rod cap were to make sure that the oil hole faced the camshaft, and that's what I did. As for ring gap, I'm not sure I follow. They are new rings, standard sized. We honed it, and I think Dad said something about he bored it .005 over or something like that.
joe
11-16-2003 10:06:32
 Re: Re: Re: John Deere 110 in reply to Matt, 11-09-2003 16:22:59
place ring only squarely in cylinder..place a feeler gauge between the ends of the ring..should have .003" clearance per inch of bore..joe
george md
11-09-2003 22:41:00
Matt,
Is the cap put on the rod backwards ?
george
