Restoration & Repair Tips Board
In.300 utility T.A.
jo
11-19-2003 11:41:23
I am looking at buying a International 300 utility T.A. one thing I noticed the shifter lever moves very stiff even when moving side to side and the oil has a grayish tint to it . Are head gaskets a common problem I have not taken a compression test yet. any advice? thanks
RAW in IA
11-27-2003 22:17:04
 Re: In.300 utility T.A. in reply to jo, 11-19-2003 11:41:23
It probably would be a good idea to change the Transmission fluid, The 300 series on up use hy=tran, and it needs changing regularly as it absorbs moisture and will effect the life of the TA ifnot changed.
TDK
11-19-2003 19:04:07
Head gaskets shouldn't be a problem.Sounds like shifter is sticking on pivot pin. Drive pin out just below shifter. Pull shifter up and out of trans.There you will find a second,larger pin.Press this pin out also.Clean pins and pin bores. Lube and reinstall all of above.Hope this helps,if not, repost and we'll try again!
