Restoration & Repair Tips Board
Charging a 8V battery
james
11-27-2003 12:11:21
How is a 8V battery charged , with a battery charger that only has 6V & 12V charging system. I have heard ....to use a reostate (sp?) between one of the charger clips and battery post . or use a resistor to get 8V at the battery on the 12V setting. What size resistor would be required ? Any info is appreciated !!
goober
12-03-2003 20:16:14
 Re: Charging a 8V battery in reply to james, 11-27-2003 12:11:21
I use an old 6v-12v charger,set on 6v high to charge my 8v batteries,never have a problem,just takes a little longer. I also use this setting to jump start the 8v tractors. I have a question?,where do you get 8v light bulbs or headlamps? Email me w/ answer. thank you,goober
goober
12-04-2003 13:02:34
 Re: Re: Charging a 8V battery in reply to goober, 12-03-2003 20:16:14
James---Thank you for the reply,I hope that the charging advice was o.k. I am using 12v bulbs now,and they are a little dim.I think that an 8v bulb would be hard to find,but they must be out there someplace. Thanks again, goober
James
12-04-2003 06:14:12
My tractor has no lights, But I believe 6V are OK ! or 12V may be a little dim.
James
12-04-2003 06:10:43
Nathan
11-27-2003 19:40:25
It would probably be easiest, and work the best, to have an 8 volt battery charger built.
Give these people a call-- they can build it for you no problem:
3W Electronics of Minnesota
638 Mendelssohn Avenue North
Golden Valley, MN 55427
(763) 498-7630
I wouldn't think that it would be too expensive and they're good people to work with!
Hope this helps,
Nathan
Sam
11-29-2003 11:42:16
 Re: Re: Charging a 8V battery in reply to Nathan, 11-27-2003 19:40:25
Would a 6v charger set on high work for a 8v battery? Or a 12v charger set on low?
Nathan
11-29-2003 20:22:19
 Re: Re: Re: Charging a 8V battery in reply to Sam, 11-29-2003 11:42:16
I'm not sure what the "High" and "Low" settings mean, but I would guess that it is probably high and low current, and if that's the case, no.
Nathan
Nathan
11-27-2003 20:56:07
So sorry-- I posted the wrong phone number originally. It should be (763)593-2700.
Nathan
