Restoration & Repair Tips Board
Re: Re: I'M HAVING BIG TROUBLE WITH MY IH 444 TRAC
Ol Chief
11-27-2003 18:15:19
As mentioned in a previous post,look for vator lock.However in addition,you may have a condenser or coil break down with heat.As a young lad I worked in a shop that owned a coil and condenser test apparatus.This rig heated the units under test while under load and I was suprised at the results sometimes.This outfit would show up a heat breakdown every time a faulty part was exposed to heat test.Also think back to when this first occured and try to recall any conditions that might have led to the problem.
