Power steering
ed
12-12-2001 15:55:19
on my ford 841 the power steering is not working well the belt is tight and fluid level and filter is new. i need to no what the pressure should be at the pump and at the ram,and how i should go about checking this, thank you all.ED
Power Steer.....
12-16-2001 07:18:00
 Re: power steering in reply to ed, 12-12-2001 15:55:19
The press. should be approx. 750 psi.(no higher than 1000 psi) and shouldn't vary more than 100 psi or so.
either on press line on pump or one of lines on cyl. put tee and 2000 psi or great guage on and start tractor and turn wheels all the way to stops. should be about same press at idle and maybe 50 to 100 psi more at high idle.
