Restoration & Repair Tips Board
cracked head - cub
Dick W.
11-30-2003 10:46:47
I am trying to help a friend get an old (1949) Cub up and running....it had been sitting for 5-6 years with no coolant or gas. After going through carb, wiring, plugs, etc. I finally got it running last night. Runs smooth, hydraulics work.....I'm feeling real good! Then all of a sudden I start to see a tell tale puddle of coolant on the garage floor. Further inspection shows a hairline crack on the top of the head were is is leaking..... very small amount, but still leaking. I am not a mechanic but have fair mechanical skills. Can the head be fixed? What should I do? Cost? Do I need to worry about the possibility of a cracked block too?...and how would I check for that?
Thanks in advance for any help.
Jerry B
12-02-2003 06:34:21
 Re: cracked head - cub in reply to Dick W., 11-30-2003 10:46:47
Replace the head. I think the head is still being made as I see them in advertisments from time to time.
The head will have to come off anyway, and while it is off, check for cracks in and around the cylinders. Check the outside of the block near the bottom of the water jacket for small cracks as well.
