Restoration & Repair Tips Board
Motor dies when hot
Chris Davie
12-02-2003 16:51:24
My ride-on has a Briggs & Stratton 8 HP motor on it which dies after about 10 minutes of running. Have cleaned tank & carby out. Still spark after it dies.
I'm no engine wiz so if you have a suggestion, please keep it simple.
Dave
12-09-2003 11:10:42
 Re: Motor dies when hot in reply to Chris Davie, 12-02-2003 16:51:24
Chris,
Check the routing of the fuel line, it may be routed to close to the engine, thus causing vapor lock(fuel is being heated to high). Otherwise thee other two posts are well worth examining.
Dave
Bob
12-07-2003 16:06:43
Check the vent in the gas cap to make sure is open. I've fixed this problem on new mowers with the shipping plug left in the tank under the cap. Just an idea.
Rusty Jones
12-03-2003 20:21:55
Check the spark plug wire to see if the heat from the engine softens the wire coating, making it bend down and touch the engine, thereby shorting out the wire! When the engine stops, by the time you pull the plug wire off, it may be cool enough to stiffen up, and you have moved the bad spot away from where it is touching! Also, look for a bare spot on the plug wire. And, try a new spark plug! Use Champion plugs! RJ
Todd
12-11-2003 18:32:19
 Re: Re: Motor dies when hot in reply to Rusty Jones, 12-03-2003 20:21:55
I have heard of this problem and most say they replaced the coil and all was good...
