Restoration & Repair Tips Board
Frost Plug installation - how to?
Ted
12-05-2003 11:20:57
I have a 1947 Farmall A torn all the way down and had the old frostplugs removed when the block was boiled out. Any tips on how to re-install the new plugs?
TDK
12-05-2003 21:07:55
 Re: Frost Plug installation - how to? in reply to Ted, 12-05-2003 11:20:57
Clean plug bore of any rust,etc. with 220 sandpaper.Put small amount of sealer of your choice around outer edge of plug.Using a driver of same diameter as plug or a flat piece of heavy metal slightly larger than plug,drive plug straightly into bore until flush with engine block.Wipe away any excess sealer & your done.Have used this method for 20 yrs. with no problems & no leaks.Hope this helps!
David
12-08-2003 04:32:08
 Re: Re: Frost Plug installation - how to? in reply to TDK, 12-05-2003 21:07:55
Exactly. That's what I do too.
