Restoration & Repair Tips Board
NAA carb
bdhszy1
12-24-2003 07:55:12
got a 1954 NAA for Christmas,my first old tractor,so I'm new to this old stuff.The carb is in need of rebuilding,and when I took it off and turned it over,there is a small(about 1/4 inch)brass plug in the bottom,which has a small hole about in the center.Looking down the top of the carb i can see right thru this hole.Is this normal?Is this hole supose to be there?Thanks for any help,I'm sure there will be lots more questions to come.
John K
12-25-2003 07:01:15
 Re: NAA carb in reply to bdhszy1, 12-24-2003 07:55:12
I work on Lincolin welders, on their updraft carbs they al so have a a brass plug in the bottom. The plug has a dense cintered screen in the center. I have assumed that was for fuel to drain out if for any reason the float was not shutting off the fuel supply. I use carb cleaner to make sure it is clean, when clean you can hardly blow through it. I can not see through it. It must have some sort of screen or else you will be getting contaminates into the engine. Hope this helps.
old
12-24-2003 20:02:13
Sounds like you are missing the mainjet or it has gotten water in it and frooze the carb should be a TSX428 and you a should be able to get a kit for it or you might want to get a new /rebuilt carb for it cost is around $170 for a rebuilt one
bdhszy1
12-25-2003 05:16:32
 Re: Re: NAA carb in reply to old, 12-24-2003 20:02:13
The carb is model TSX692,is this the wrong model for an NAA?When I took the carb apart there were no parts in the bottom.Does this explain why the tractor would idle but not rev up?Thanks Richie
old
12-25-2003 08:40:26
 Re: Re: Re: NAA carb in reply to bdhszy1, 12-25-2003 05:16:32
That carb is for a 600 or 700 ford tractor. Sounds like you need a complete rebuild kit for it if you send me an e-mail I can give you a phone number for a place that has kits and or a carb oldcoal@earthlink.net
