Restoration & Repair Tips Board
Farmall F-20
Jeff D.
12-29-2003 18:51:06
Does anyone have any suggestions on how to unstick an F-20? I filled a crank case and cylinders with PB Blaster. Is there something else I could be doing other than this?
Bill Smith
01-08-2004 12:09:45
 Re: Farmall F-20 in reply to Jeff D., 12-29-2003 18:51:06
Everybody is going to recommend a wide variety of liquids to soak in the cylinders. I use and recommend automatic transmission fluid. It may take quit awhile (maybe months) for the soaking to do any good. If you suspect that it is froze really good, you may as well pull the head off. If sleeves are pitted really bad, you're more than likely going to want to try to remove that piston out the bottom of the sleeve. If soaking doesn't free things up over a period of time, you will probably want to resort to an act of force. Putting a block of wood on top of piston and pounding on the wood (or something of that nature).
Jeff D.
01-09-2004 14:58:21
 Re: Re: Farmall F-20 in reply to Bill Smith, 01-08-2004 12:09:45
Thank you, I am soaking them now. It has been bitter cold and below zero at night and not above ten in the day. I am soaking them with a high quality diesel fuel lubricant additive. Thank you for your feedback. I'll let you know when it moves. I did look in the cylinder and did not see any pits.
F-20 Man
01-05-2004 17:49:53
Hey Jeff just wanderin if u got ur F-20 motor unstuck iv tried almost everything on mine if all else fails i had too use a 1 inch steel rod about 2 feet long and come under the piston and make sure you hit the bolt that holdes connecting rod to the piston of course there is prolly always a consequense i broke the bottom of the skirting off one of my pistons well hope the info helps love to here back on how it all worked out
The F-20 Man
old
12-29-2003 19:54:57
Try some old fahsion turpentine on top of the PB blaster, I've used it in a lot of stuck engines and have yet to not unlock one
JD
12-29-2003 20:43:07
 Re: Re: Farmall F-20 in reply to old, 12-29-2003 19:54:57
Thank you I will try that tomorrow.
