Restoration & Repair Tips Board
JD B water in motor oil
Ed in N.H.
01-03-2004 14:30:52
Just bought a 1950 B to restore.found alot of water in motor and trans oil. its been sitting for a few years,motor is stuck. any ideas how it got in?exhaust was always covered,and air stack is shielded.was thinking got in trans. through shifter?not sure about motor.
john
01-27-2004 11:30:47
 Re: JD B water in motor oil in reply to Ed in N.H., 01-03-2004 14:30:52
I would drain the crankcase and let it sit till it stops dripping. Fill the block with water. If water begins to run out of the crankcase drain then you know u have a problem and not just rain water of condensation. The brass tubes in the head are bad to leak and rot away. Especially for the folks against anti-freeze. A pressure check on the head at a local machine shop will tell you if the tubes are leaking. If I had the head off, I would replace the tubes anyway. Deere still has em, or at least did a year ago. If not, I machine shop could make out of tubing. Nothing complicated.
John
George
01-03-2004 20:45:01
Cracked head or block, or a leaky head gasket. One way that people often overlook are the brass pushrod sleeves in head having pinholes --- I always replace them when doing a valve job just for insurance.
Once you fill up the crankcase with water, it will flow into the transmission case.
old
01-05-2004 19:23:49
 Re: Re: JD B water in motor oil in reply to George, 01-03-2004 20:45:01
Condesation I have a JD-B that had the same problem and I know it could only be from that because I had it in my site for years before I got it up and running
i r baboon
01-04-2004 11:56:09
maybe just rain before can was put on ex
