Restoration & Repair Tips Board
Help! Ford 8N Tractor Question
Beaver Baker
01-13-2004 18:00:18
Can anybody help me? I have a 1950 Ford 8N and having problems with steering.I replaced the steering assembly,tried to start it, but the motor would not turn over.(made sure it was not locked up) I assumed the starter was bad, so I replaced starter and drive, but still having the same problem. Starter acts like it is in a bind and won't turn motor over. I don't know what else to check.
Nolan
01-14-2004 11:24:39
 Re: Help! Ford 8N Tractor Question in reply to Beaver Baker, 01-13-2004 18:00:18
Dirty connections and inadequate wiring are the bane of six volt starters. Check your wiring and connections over closely. It's very easy to have enough connection to make a starter tick over, but not enough to crank the engine.
Bernard Mudd
01-17-2004 06:00:19
 Re: Re: Help! Ford 8N Tractor Question in reply to Nolan, 01-14-2004 11:24:39
To eliminate timing problems or soome other mechanical problem. Can the tractor be pull started. Pull with another vehicle or roll of of a incline. Place in 4th gear and release clutch with ignition switch on engine should start and run. We had a 8N ford Some times known a a hill side tractor to us. You started out discribing a steering problem. The steering can bind in front axle if not propely maintained.
