Restoration & Repair Tips Board
8N tractor tire
Michael Daly
01-14-2004 15:43:16
Old workhorse with a sloooow (noticed over three years) leak from left rear. Outside rim is stained but not wet. Looks like it's down about a fifth or a quarter of original volume. I've got fluid in the tire (gushed out when I tried to add air) and I assume it's CaCl. Can or should I add air to the tire, or more CaCl solution? Is a special pump needed to add the fluid? Checked the forum for tire questions, but none were so basic as mine. Thanks.
Brad
01-15-2004 12:41:01
 Re: 8N tractor tire in reply to Michael Daly, 01-14-2004 15:43:16
My opinion...Unless you absolutely have to have the weight in back, I would get the CaCl out of both rear tires. And if you have a leak, then it is a sure thing, that in time, your rim will be destroyed by corrosion.
old
01-14-2004 18:14:16
Unless its flat all you need to do is add air, works better if stem is in the 12 o'clock position
