Restoration & Repair Tips Board
Changing front ends on a
Bill Simons
01-16-2004 17:11:06
I have put a wide frontend on my C and now the wheels turn the wrong way. This is a Allis C. Can someone give me some help?
Dick L
01-18-2004 16:46:53
 Re: Changing front ends on a in reply to Bill Simons, 01-16-2004 17:11:06
You must have put a front axle assembly from a B. If so you need a stearing box from a B to change the rotation of the stearing wheel.
ELW/TN
01-17-2004 15:55:29
Takes awhile, but you'll get used to it.
cole in mo.
01-20-2004 05:17:25
 Re: Re: Changing front ends on a in reply to ELW/TN, 01-17-2004 15:55:29
Years ago at the salvage yard we had a front endloader that steered backwards, wasn't bad around the lots, but once a week we had to drive it on the major hiway 3 miles and back, quite a trip meeting traffic knowing you had to turn towards them to go the other way.
SmallOps
01-19-2004 04:19:13
ELW has a good point. But I have to add that the transistion is easier if you reverse the seat 180 degrees and mount a rearview mirror so you can see forward when setting in the newly positioned seat. 8^)
P.S. If the neighbors give you a hard time while you're learning, just wear a large floppy hat, a red bulb on your nose and some big clunky shoes. Then you won't look so "conspicuous", while you adjust to the new steering techniques. ;^)
