Restoration & Repair Tips Board
removing grease from radiator fins on 720
Blane Hulle
01-20-2004 16:39:31
I have just bought a 720 diesel that had a really bad powersteering leak for probobly the past 15 years and the oil and air particles have been caking up and are about a half an inch thick and I was wondering if anyone knew the best way to get grease out without bending and flattening the fins. Thankyou
Darryl
02-07-2004 13:59:22
 Re: removing grease from radiator fins on 720 in reply to Blane Hulle, 01-20-2004 16:39:31
I have a 420 that has had a grease leak in the steering box for years. I finally had to get the grease out of the fins. I tried lots of stuff which only worked fair. The answer came when I borrowed a friends steam cleaner. I lowered the pressure to a point where it wouldn't knock done the fins and it was looking like new in nothing flat.
Road Warrior
01-20-2004 20:37:42
Try using some engine degreaser, I've had good luck with Gunk. You may have to let it soak a while and spray it several times if it's that dirty.
I've even used a siphon tube with a blow gun and sprayed soapy water on radiators. It works ok, as long as it's not really dirty.
Just make sure you get the radiator dry before operationg in a lot of dust or weed seed, or it will plug up quick.
Blane Hulle
01-20-2004 21:01:05
 Re: Re: removing grease from radiator fins on 720 in reply to Road Warrior, 01-20-2004 20:37:42
Thankyou
