Restoration & Repair Tips Board
1964 Briggs 5hp, keyway very stuck! Removal?
Aaron
01-27-2004 15:54:09
I have a 1964 (I believe... possibly a little older) horizontal shaft Briggs motor that was on a snowblower back in the day. I'm trying to rebuild it as a fun project... but I have walked away very angry several times!
It had two v-belt pulleys on it... those were interesting to get off without a puller, but I managed to do it. My problem is the keyway (I think that's what it's called!
It is stuck on the cranksaft so well that even a flathead screwdriver and a hammer won't budge it! What can I do?
Farmallmaniac
02-01-2004 12:36:42
 Re: 1964 Briggs 5hp, keyway very stuck! Removal? in reply to Aaron, 01-27-2004 15:54:09
get a wet rag and wrap it around the shaft by the seal and use a torch to heat up the key and it should come out with a hammer and chisel
Aaron
02-01-2004 14:10:32
 Re: Re: 1964 Briggs 5hp, keyway very stuck! Remova in reply to Farmallmaniac, 02-01-2004 12:36:42
I have tried all the methods suggested; torch, penetrant, and brute force... but it has not budged at all.
Can I cut it out?
pushin340
01-27-2004 16:03:24
I would use a mig welder to tack a stud on to it then use a slide hammer to pull it
BFarr
01-27-2004 15:59:16
It is amazing how stuck those keys can become after 40 years :>
If you use heat you will likely damage the seal.
I have had luck with PB Blaster (or whatever juice you prefer), letting it soak for days perhaps and each day just tapping the key upward with a sharp cold chisel. It will jar loose and once it moves just a little you are home free..
