Restoration & Repair Tips Board
6 volt gen check
bill
01-27-2004 17:20:15
how do you check 6volt gen off the tractor?it is off of my 8n.
steve
01-30-2004 18:56:42
 Re: 6 volt gen check in reply to bill, 01-27-2004 17:20:15
you can spin it with a 1000 rpm drill, or motor, or easiest to stick back on the tractor. ground the "F" terminal to the case. spin generator and measure the voltage across the "F" and "A" terminals. should be 7- 15 volts or so. When you connect to a voltage regulator you will trim that to 6.8 volts for a 6 volt system. I have an amgle iron frame with a 1/3 hp washing machine motor setup to test alternators and generators. has a battery for complete test. AFter testing generator, you connect the regulator, then see if the "system" works.
