Restoration & Repair Tips Board
Turpentine in stuck engine
Bob in OK.
02-05-2004 19:29:26
Just read a post about putting turpentine in stuck engine said should be old type rather than new paint thinner stuff. Where can you buy it how do I know if it old stuff?
Fern(Mi)
02-07-2004 09:03:41
 Re: Turpentine in stuck engine in reply to Bob in OK., 02-05-2004 19:29:26
Maybe if one were to massage the turpintine in.
old
02-07-2004 14:29:49
 Re: Re: Turpentine in stuck engine in reply to Fern(Mi), 02-07-2004 09:03:41
Fern have you ever tried it??? It works very well and as far as penatration that it is good at also
Fern(Mi)
02-07-2004 16:42:18
 Re: Re: Re: Turpentine in stuck engine in reply to old, 02-07-2004 14:29:49
I'll give this a try Les. Thanks.
My above post I was merely having a little fun in pointing out there is more than one turpintine. I have used both. The paint thining variety used also for a paint drier. Paint thinner (Or oleom spirits was used only as a paint thinner. The second even further out and above out of context turpintine is a heavy syrupy fluid made for medicinal purposes, perhaps a muscul liniment.
I doubt its used much any more. Thanks again for the enlightenment.
I've got one stuck engine I'd like to free up before Spring, if not next winter.
Have a good one.
old
02-07-2004 18:54:09
 Re: Re: Re: Re: Turpentine in stuck engine in reply to Fern(Mi), 02-07-2004 16:42:18
Well I find it best to fill the cylinders with oil/tranny fluid etc. first then a week or so before you are ready to work on that engine fill them with the gum spirits of turpentine and you will probably have a runner. And ya I understand a little LOL
Bill Smith
02-06-2004 11:34:25
I have come to be a believer in using automatic transmission fluid for a soaking solution in stuck engines. I have tried alot of different things but certainly not everything, including turpentine. This is one of those deals where if you ask 100 people what to use, you will get 75 different answeres. I might just try the turpentine next time and just see if it is better than ATF.
old
02-06-2004 19:16:05
 Re: Re: Turpentine in stuck engine in reply to Bill Smith, 02-06-2004 11:34:25
Well I have tried just about every thing over the last 40 years from coke to tranny fluid and oil etc and ever since I tried turpentine I've had more luck in less time then with all the rest. But any more its getting hard to find true turpentine
olen
02-26-2004 20:21:52
 Re: Re: Re: Turpentine in stuck engine in reply to old, 02-06-2004 19:16:05
old,look up a product called evapo-rust and it will put all the other stuff to shame,good luck
old
02-06-2004 08:09:13
If its the old stuff it should say mineral spirits on the can, you probably where reading one of my posts. The old stuff is getting hard to find, the last stuff I got I brought all the place had and was told they will not ever have any more.
Ben in KY
02-06-2004 07:09:27
I think the new stuff says something like turpentine substitute or something like that on it. I have a can of turpatine that is like that. I think if it says turpentine on it it must be genuine. But I have been wrong before :)
Robert in Md
02-06-2004 19:00:26
 Re: Re: Turpentine in stuck engine in reply to Ben in KY, 02-06-2004 07:09:27
Mineral Spirits is a oil product and is available everywhere. About $2.50 per gallon. Its between kerosene and gasoline and is almost odorless. Turpentine is refined Pine tree sap and has a distintive odor. Cost $5-$10 per gallon. Use to be used for paint thinner but not much anymore.
Fern(Mi)
02-08-2004 02:14:09
 Re: Re: Re: Turpentine in stuck engine in reply to Robert in Md, 02-06-2004 19:00:26
Herr Clink has beeb refining a sap for the lasy 45yrs; but, I ain't given in yet.
Jerry
02-13-2004 16:58:27
 Re: Re: Re: Re: Turpentine in stuck engine in reply to Fern(Mi), 02-08-2004 02:14:09
I pour in Mystery oil in each cylinder and follow up with 120 psi of air for several hours.
