43 FARMALL H ?? MAGNETO PROBLEMS ?? HELP.
BBB
12-24-2001 00:54:52
I NOTICED MY TRACTOR ACTED WEAK AND DIED.
I CHECKED FOR SPARK AT THE PLUGS WITH TIMING LIGHT. I ONLY HAD SPARK AT # 4. MAIN WIRE WAS ERRATIC WITH LIGHT. 12VOLT CRANKING. H-4 MAGNETO. RECENTLY REPLACED POINTS, PLUGS, WIRES, CONDENSOR. AFTER TUNE UP SEEMED TO RUN GOOD. HAVE LESS THAN 4 HOURS ON TUNE UP. NOW BACK FIRES AND WILL NOT START.
LOOKING FOR SUGGESTIONS.
THANKS.
Wayne Swenson
12-29-2001 20:39:39
 Re: 43 FARMALL H ?? MAGNETO PROBLEMS ?? HELP. in reply to BBB, 12-24-2001 00:54:52
Did your points slip out of adjustment?
BBB
12-30-2001 20:37:52
 Re: Re: 43 FARMALL H ?? MAGNETO PROBLEMS ?? HELP. in reply to Wayne Swenson, 12-29-2001 20:39:39
Thanks for the assistance with red.
This time the points were ok. (.013 setting).
After reading 1173 tidbits from the tractor discussion archives, I was able to get a clearer understanding of what is supposed to happen. I was able to do a bench test with the magneto.
Thus the main coil was replaced - weak spark / some of the insulation off of the old coil must have heated and dripped onto the magnets below.
I cleaned the rust and debris from the impulse coupling then lubricated it. Reinstalled magneto to the proper timing.
My kill switch was erratic. Replaced it. I still only had spark to a couple of cylinders.
At this time I was only using a timing light to determine if I had spark.
I used my super human brain to figure this one out. I used a 1/4-20 bolt as the spark plug I held it with pliers about 1/4 in. from the block while cranking motor - clearly I had good spark to all cylinders.
Thats when I realized that the spark plugs that were sold to me as part of the tune up kit were Champion d15y. I changed to Champion D21y (2 levels hotter) now I have good spark. She's running great. I can almost start her with the hand crank. My next challenge will be to rebuild the carburator - I see it leaks some gas from gasketed areas.
Any takers for words of wisdom in this department?
Thanks again.
BBB
